[SOLVED] [BUG?] [workaround] SES v3.30 hangs on startup when source control exe path set incorrectly
  • [SOLVED] [BUG?] [workaround] SES v3.30 hangs on startup when source control exe path set incorrectly
    Reproduction
    SES v3.30
    0. one instance of SES opened with a project using git source control
    1. settings-> source control -> git exe set to git-cmd.exe (the correct would be git.exe)
    2. close SES
    3. start SES, hangs before project files are shown
    Symptoms
    Unable to change settings to fix the problem due to SES hang
    Possible solution
    don't allow selection of incorrect git.exe
    workaround
    0. force close SES
    1. remove reference to incorrect executable in 'C:\Users\[username]\AppData\Local\SEGGER\SEGGER Embedded Studio\v3\settings.xml'
    2. start SES and set correct executable
    What exactly is the question?
    If you have troubles setting up version control in ES we recommend the following wiki article: wiki.segger.com/Embedded_Studio_VCS_configuration
