ICONVIEW Widget and External Memory
  • ICONVIEW Widget and External Memory
    Good Afternoon,
    I am attempting to use the ICONVIEW_AddStreamedBitmapItem API to add a bitmap from external memory (a SPI-Flash). I am just wondering if there is a way to accomplish this in a way that will just call to a GUI_GET_DATA_FUNC callback. Is this capability available? I'm assuming that it would be something that GUI_BMP_DrawScaledEx?
    Is this possible/a valid usage of the function?
    Thank you,
    Mathew
    Unfortunately, this is not directly possible when using the ICONVIEW API.
    But you can set a custom owner draw function and react on WIDGET_ITEM_DRAW_BITMAP. When reacting on this command you can simply draw a streamed bitmap.
    I have attached an example on how this could be done. It uses the windows API for opening a file handle. Simply adapt the paths in _GetImageById() to point to your dta-files.
    of course, I forgot to attach the example.
    Here you go.
