[SOLVED] Plotting variables as a graph feature, name auto-completion feature available on SES 3?
  • [SOLVED] Plotting variables as a graph feature, name auto-completion feature available on SES 3?
    Hi, I'm Matthew. I use
    - 64-bit SES 3.26 on 64-bit Windows 10
    - J-Link Plus or onboard J-Link (Nordic's dev kits have a J-Link on the board itself)
    - J-Link 6.16h
    - Nordic's PCA10040 v1.1.1 board (this board uses nRF52832-QFAA MCU)
    - STM32F4 Discovery board
    - TI's TM4C123GXL board
    I'm trying to migrate to SEGGER ES. I used IAR EWARM, Keil MDK, TI's CCS 7 in the past.
    CCS provided a graph plotting feature (workshop book page 195) ;
    -link, FPU workshop video
    -link, graph video demo using MSP430
    After selecting a memory region and choosing the data type (32-bit float, int, etc), CCS plots a graph.
    1. I think this is a great feature, especially when checking ADC values using a graph.
    Does SES 3 provide a similar feature like this?
    2. If not, how can I dump a memory region in binary/float/int/etc type?
    If this feature not available, I think an alternative way is to dump values and plot it using Matlab or something.
    3. Lastly, is there an auto-completion feature in SES 3?
    For instance, Keil MDK provides a Code Completion feature .
    After typing 2 or more words, I hope SES to suggest a function name or struct/union member name.
    Is this possible? Do I need a keyboard shortcut to do this?
    -Best Regards
    P.S.) If the graph features not available, I wish to suggest this feature, please! :D
    -Best Regards, Matthew
    The post was edited 1 time, last by MatthewKyeo ().
  • Hello Matthew,
    Thank you for you inquiry.
    Not directly in ES but you have two options here:
    1. Either use Ozone and "Data Graph" window.
    2. Use our external visualization tool J-Scope that can run in parallel to ES: segger.com/products/debug-probes/j-link/tools/j-scope/
  • Hi Matthew,
    Sorry i missed that question.
    Yes we have a auto-completion feature which requires no configuration from your side. Just make sure the function/variable etc. you want to autocomplete is included in the file you are editing currently.
  • Hi, Nino. I see.
    I wrote that question because the auto-completing tab didn't appear when I was typing #define MACROs in the SES editor or I waited quite awhile to let SES auto-complete it.
    I will take an eye on that. Thanks for your reply. Case solved!
    If I have trouble using the "data graph" feature from SEGGER's Ozone, I will post another question thread.
    -Best Regards
  • Hello Matthew,
    Under some weird circumstances auto complete will not function properly. Usually restarting ES already fixes that problem for most users. Should you find a solid reproduction scenario we would appreciate to hear it so we can figure out where this quirk is coming from.
    Alright do that.
