J-Flash ARM 3.78c command line problem
  • J-Flash ARM 3.78c command line problem
    Hello:
    I am currently using J-Flash Arm 3.78c through the command line and having trouble piping the output to a file using the “>” command. the US support did experience the same problem where the file gets created without any output. My command that I used is as Follow:
    JFlashARM.exe -openprjC:\Projects\AmigoUTForMainBoardTester\bin\Debug\AT91FR40162.jflash -openBootstrap_Loader.hex -auto > log.log
    any help will be greatly appreciated!!
  • You may want to try something similar to the following. If I run the following batch file everything works as expected.
    @ECHO OFF
    JFlashARM.exe -openprjC:\Projects\AmigoUTForMainBoardTester\bin\Debug\AT91FR40162.jflash -openBootstrap_Loader.hex -auto -exit
    ECHO ERRORLEVEL: %ERRORLEVEL%
    ECHO %ERRORLEVEL% > log.log
    IF ERRORLEVEL 1 GOTO ERROR
    ECHO SUCCESS!
    GOTO END
    :ERROR
    ECHO ERROR!
    :END
    If I run with cable or power disconnected the output is:
    C:\test>test.bat
    ERRORLEVEL: 1
    ERROR!
    If everything is connected as it should be, I get the following:
    C:\test>test.bat
    ERRORLEVEL: 0
    SUCCESS!
    I hope this helps.
    The post was edited 1 time, last by SEGGER - Shane Titus ().
