[SOLVED] SAMD21G peripheral SVD file issue
  • [SOLVED] SAMD21G peripheral SVD file issue
    Hi all.
    When using peripheral SVD file got from atmel repository (packs.download.atmel.com/) registers are not shown in Ozone 'Registers' window for a few peripherals: SERCOM, TC, RTC, USB.
    As far as I can see all such devices have the keyword 'cluster' in the SVD file while devices without 'cluster' are shown correctly.
    Any suggestion will be highly appreciated as I have to debug serial port initialization
    PaoloC
    ,ATSAMD21G18A_svd.txt
  • Hello Paolo,
    thank you for your inquiry.
    This issue should be fixed in the next Ozone release version so you can keep using your .svd file.
  • Hello Paolo,
    Great to hear that you are up and running again and thank you for the flowers :)
    I will consider this case as closed then.
