[ABANDONED] Guessing TRST - meaning of printouts during halt
  • [ABANDONED] Guessing TRST - meaning of printouts during halt
    I'm trying to connect to a board with 2 unknown chips (Segger tells me they have an ARM7 and ARM9 core) and an unusual 10 pin header where I only know the position of TMS, TDI, TCK, TDO, GND and VREF. I've connected these pins to the JLINK EDU, and am guessing the location of TRST.
    I want to halt the processor and read memory. With most guesses of TRST I'm able to connect, but cannot halt as follows:
    J-Link>halt
    Using DBGRQ to halt CPU
    Resetting TRST in order to halt CPU
    ****** Error: Unable to halt CPU core
    J-Link>go
    ****** Error: CPU is not halted
    However, with 2 guesses I get "Cannot connect to target," but halting seems to do something. The output of that is below. In no case can I ever read memory.
    Does anyone have a sense of which is correct - could the TRST guesses where I "cannot connect" but can halt be right? What do the different printouts for the not connected guesses mean?
    _____
    Guess 1:
    Device>ARM7
    J) JTAG (Default)
    TIF>j
    Device position in JTAG chain (IRPre,DRPre) <Default>: -1,-1 => Auto-detect
    JTAGConf>
    Speed>1000
    Device "ARM7" selected.
    Connecting to target via JTAG
    TotalIRLen = ?, IRPrint = 0x..FFFFFFFFFF80000000000011
    TotalIRLen = ?, IRPrint = 0x..FFFFFFFFFF00000000000011
    Cannot connect to target.
    J-Link>h
    TotalIRLen = ?, IRPrint = 0x..FFFFFFFFFFC0000000000011
    PC: (R15) = 00000000, CPSR = 00000000 (Unknown mode, ARM)
    Current:
    TotalIRLen = ?, IRPrint = 0x..FFFFFFFFFFE0000000000011
    R0 =00000000, R1 =00000000, R2 =00000000, R3 =00000000
    R4 =00000000, R5 =00000000, R6 =00000000, R7 =00000000
    USR: R8 =00000000, R9 =00000000, R10=00000000, R11=00000000, R12=00000000
    R13=00000000, R14=00000000
    FIQ: R8 =00000000, R9 =00000000, R10=00000000, R11=00000000, R12=00000000
    R13=00000000, R14=00000000, SPSR=00000000
    IRQ: R13=00000000, R14=00000000, SPSR=00000000
    SVC: R13=00000000, R14=00000000, SPSR=00000000
    ABT: R13=00000000, R14=00000000, SPSR=00000000
    UND: R13=00000000, R14=00000000, SPSR=00000000
    J-Link>go
    _____
    Guess 2:
    J-Link>con
    Please specify device / core. <Default>: ARM7
    Type '?' for selection dialog
    Device>ARM7
    J) JTAG (Default)
    TIF>J
    JTAGConf>
    Speed>1000
    J-Link>h
    Current:
    J-Link>go
    To what output message of which application do you refer?
    This output indicates that J-Link did write a test pattern to TDI, but did never received it via TDO.
    This could be caused by one of the following:
    -> TDI and / or TDO not wired correctly
    -> Debug interface is disabled on the target
    -> VTRef not connected correctly (What voltage does J-Link Commander show?)
    -> Target does not support JTAG
    When using Guess 2, do you get a valid output for TotalIRLen / IRPrint ?
    The message which tells me the types of chips is this, when I am able to connect:
    #0 Id: 0x4F1F002F, IRLen: 04, ARM7TDMI-S Core
    #1 Id: 0x1594602F, IRLen: 04, ARM946E-S Core
    I think you're right - I had VREF on the wrong pin, because previously it said VTref is 2.549 and it should be 3.3V. With guess 2 (and the wrong VREF, I think now) I was unable to connect and so didn't see IRLEN or IRPRINT.
    With VREF on the 3.3V pin, none of the other available guesses for TRST are able to halt it.
    I just get the following (below). Any ideas how I can halt this thing?
    Thanks.
    SEGGER J-Link Commander V6.16j (Compiled Jul 24 2017 18:43:04)
    DLL version V6.16j, compiled Jul 24 2017 18:42:55
    Firmware: J-Link ARM V8 compiled Nov 28 2014 13:44:46
    Hardware version: V8.00
    S/N: 268005650
    License(s): FlashBP, GDB
    OEM: SEGGER-EDU
    VTref = 3.345V
    J-Link>con
    Device>ARM7
    J) JTAG (Default)
    TIF>j
    JTAGConf>
    Speed>1000
    TotalIRLen = 8, IRPrint = 0x0011
    JTAG chain detection found 2 devices:
    WARNING: The selected device is not JTAG compliant (IEEE Std 1149.1, 7.1.1.d, IR-cells). (Expected: 0x1, Found: 0x3)
    ARM7 identified.
    ETM V1.2: 1 pairs addr.comp, 0 data comp, 4 MM decs, 1 counters
    J-Link>h
    J-Link>g
    1000 kHz fixed interface speed is probably too much for the ARM7TDMI-S Core.
    You either can use a low speed (4 - 50 kHz) or try adaptive clocking.
  • Thanks for this. I tried halting with "halt" and "rx 0" with all the 3 candidate TRST pins, with speeds of 4, 5, 15, 25, 35, 45, 50. None of them succeeded - the output is below. Adaptive clocking results in: "****** Error: JTAG Timeout during adaptive clocking: RTCK did not respond.
    Cannot connect to target."
    Is having only TMS, TDI, TCK, TDO, VREF and possibly TRST connected enough to halt the CPU? I have nothing on the Segger's DBGRQ or RESET pins.
    Here's the output:
    S/N: 268005650
    OEM: SEGGER-EDU
    VTref = 3.345V
    J-Link>con
    Device>ARM7
    J) JTAG (Default)
    TIF>j
    JTAGConf>
    Speed>4
    ARM7 identified.
    J-Link>h
    J-Link>g
    J-Link>rx 0
    Reset delay: 0 ms
    Reset type NORMAL: Using RESET pin, halting CPU after Reset
    Core does not stop after Reset, setting WP to stop it.
    Failed to halt CPU core after Reset (BP@0), using default reset strategy.
    Resetting target using RESET pin
    Halting CPU core
    Halting CPU core
    The RTCK pin (pin 11) needs to be connected in order to use adaptive clocking.
    J-Link does not use the DBGRQ pin, it accesses DBGRQ via the ICE registers.
    You should connect the nRESET pin if possible.
    You do not have more information about the target? Name, vendor, schematics?
  • Thanks again for your help. I'm guessing TRST, which I connect to nTRST on the Segger, but none of the guesses succeed in halting it. Unfortunately I don't have any schematics for this device - it's a prototype.
