Is there an event for USB disconnection?
  • Is there an event for USB disconnection?
    I'm using emUSB Driver with embOS.
    My application mount an MSD device to storage some files.
    I'd like to know if is possible or there is any callback event the emUSB-Device provide when a disconnection occurs from USB.
    Thank you!
  • No. But the blocking USBD_MSD_Task will return once USB is disconnected. You can check the connection state using USBD_GetState.
  • Dear Yan,
    I've tried to use the return after call the USBD_MSD_Task(), but I don't know why, sometimes the function don't return after disconnect the USB cable.
    I think that some reason the function blocks.
    I have some debug logs that prove it.
    Have you ever seen this before?
    Thanks.
  • That is strange, could you please post the logs?
  • Yan,
    The log I mentioned is from my application.
    It just print on a log.txt file saved on SD Card:
    • "USB Connected" when run the task USBD_MSD_Task()
    • "USB Disconnected" when the function USBD_MSD_Task() returns.
    Sometimes the message "USB Disconnected" does not happens.
    Is there some DEBUG flag that I'm able to show more useful messages for you?
    Thanks.
  • Yes, with the define DEBUG=1
    you can use
    1. USBD_SetLogFunc(USB_X_Log);
    2. USBD_SetWarnFunc(USB_X_Warn);
    3. USBD_SetLogFilter(0
    4. | USB_MTYPE_INIT
    5. | USB_MTYPE_CORE
    6. | USB_MTYPE_CONFIG
    7. // | USB_MTYPE_DRIVER
    8. // | USB_MTYPE_ENUMERATION
    9. // | USB_MTYPE_TRANSFER
    10. // | USB_MTYPE_IAD
    11. // | USB_MTYPE_CDC
    12. // | USB_MTYPE_HID
    13. | USB_MTYPE_MSD
    14. // | USB_MTYPE_MSD_CDROM
    15. // | USB_MTYPE_MSD_PHY
    16. // | USB_MTYPE_MTP
    17. // | USB_MTYPE_PRINTER
    18. // | USB_MTYPE_RNDIS
    19. // | USB_MTYPE_RNDIS_INTERN
    20. // | USB_MTYPE_SMART_MSD
    21. // | USB_MTYPE_UVC
    22. // | USB_MTYPE_ECM_INTERN
    23. );
    The USB_X_Log/USB_X_Warn are located in the USB_ConfigIO.c file, if possible you should use RTT as it influences the timing the least of all possible I/O methods.
  • Uhhh, this is ancient. Please update to the newest.
