Hi all,
I am using the J-Link ARM Flash,
it works fine, but I received the following error with the Target
DNP9200 (ST91RM9200 with Flash Intel 28F128J3 at Address 0x10000000 ). Reading with no problem. Flashing with Fail. I am use 2 J-link ARM adapter (1x privat+1x at working). The Problem are the same with both. ( Programm Segger J-Flash ARM V4.10d)
Reading entire flash chip ...
- 128 sectors, 1 range, 0x10000000 - 0x10FFFFFF
- RAM tested O.K.
- Target memory read successfully. (16777216 bytes, 1 range) - Completed after 21.448 sec
Saving data file [C:\Program Files (x86)\SEGGER\JLinkARM_V410d\dnp9200.mot] ...
- Data file saved successfully (16777216 bytes, 1 range)
Erasing chip ...
- Erasing 128 sectors, 0x10000000 - 0x10FFFFFF
- RAM tested O.K.
- Erasing sector 0
- ERROR: Failed to erase sector 0 @ address 0x10000000 (Algo10: Low programming voltage)
- ERROR: Failed to erase chip
Disconnecting ...
- Disconnected
What could be causing this message ?
andreas
- RAM tested O.K.
Erasing chip ...
- RAM tested O.K.
- Erasing sector 0
Disconnecting ...
- Disconnected
andreas
