SystemView V2.50 - only loading 5 events (113 bytes) from target
  • SystemView V2.50 - only loading 5 events (113 bytes) from target
    I have SystemView working ok. in 'normal mode', but would now like to switch to post mortem mode.
    When I do this (following instructions on segger.com/products/developmen…t-mortem-mode/#tab-3559-5), then run the target, stop the target after a while and read the data from target (Target->Read Recorded Data) it only loads 5 events (Start, System Info, 2x System Description Entries and Target Time).
    When inspecting the buffer it appears to be filled as expected.
    What could be going wrong?
  • I did some further work on this .....
    The Host Application Behaviour is still the same, i.e. when I perform a 'Read Recorded Data' the application still only appears to load 5 events.
    However, if I save the data from the target buffer into a binary file as described here: segger.com/products/developmen…t-mortem-mode/#tab-3559-6 and subsequently load this file into the Host application I do see sensible activity.
    Any idea why Read Recorded Data might not work?
