Hi!
I have two exec. files. part1.elf and part2.elf. They share the same flash memory area inside my LPC2366. Hence, part1.elf is a bootloader.
Is it just as easy as running
arm-elf-gdb.exe -x lpc2366_rom_jlink.gdb part1.elf
arm-elf-gdb.exe -x lpc2366_rom_jlink.gdb part2.elf
after eachother in the commando prompt?
Does the GDB erase the flash area used by the corresponding .elf file before programming?
My lpc2366_rom_jlink.gdb file contains the following:
target remote localhost:2331
monitor flash device = LPC2366
monitor flash download = 1
monitor flash breakpoints = 0
monitor endian little
monitor speed adaptive
monitor reset
monitor long 0xE01FC040 = 1
load
quit
I have noticed that if the quit command is replaced by continue command, the arm-elf-gdb.exe does not quit. I.e. the second program call cannot be executed.
Is there a better way of doing what I´m trying to do here?
Thank you.
monitor reset
load
quit
Thank you.
