EDIT_SetValue does not return
  • EDIT_SetValue does not return
    I am using the emwin library as part of a bigger embedded application. I am experiencing a bit strange behavior:
    I am using the EDIT_Widgets to visualize some data (like current temperature, etc).
    My dialog looks like the following
    1. static void _cbDialog(WM_MESSAGE * pMsg) {
    2. WM_HWIN hItem;
    3. float fDummy;
    4. fDummy = -999999999.567;
    5. switch (pMsg->MsgId) {
    6. case WM_INIT_DIALOG:
    7. vInitDialog(pMsg);
    8. break
    9. case SOME_OTHER_EVENT:
    10. vUpdateActualSetpoints( pMsg);
    11. break
    12. ...
    13. }
    14. static void vInitDialog(WM_MESSAGE * pMsg){
    15. WM_HWIN hItem;
    16. hItem = WM_GetDialogItem(pMsg->hWin, ID_EDIT_6);
    17. WIDGET_SetEffect(hItem, &WIDGET_Effect_None );
    18. EDIT_SetFloatMode(hItem, 30, 10, 50, 2, GUI_EDIT_SUPPRESS_LEADING_ZEROES);
    19. }
    20. static void vUpdateActualSetpoints(WM_MESSAGE * pMsg)
    21. {
    22. WM_HWIN hItem;
    23. float fDummy;
    24. hItem = WM_GetDialogItem(pMsg->hWin, ID_EDIT_6);
    25. fDummy = -999999999.567;
    26. EDIT_SetFloatValue( hItem, fDummy );
    27. }
    This is a very simplified example. My problem is here, that the function "EDIT_SetFloatValue( hItem, fDummy );" in line 28 does not return. Since this functions hols a mutex in my application, it blocks every functionality that needs that mutex.
    However, if I insert "EDIT_SetFloatValue(hItem, 0);" after line 20, the program works and the function "EDIT_SetFloatValue" inside my "vUpdateActualSetpoints" does return. Also, if I change the value in line 27 to be between 10 and 50 it returns.
    Is this behaviour known and intended? Is there a way to make sure, the emWin functions do always return?
    I gave it a try but on my end it is working as expected.
    If I try to set a value of -999999999.567 it shows 10 as configured.
    Which version of emWin are you using?
    Here is the application I have used for testing:
    2. *
    3. * Defines
    4. *
    5. **********************************************************************
    6. */
    7. #define ID_WINDOW_0 (GUI_ID_USER + 0x00)
    8. #define ID_EDIT_0 (GUI_ID_USER + 0x01)
    9. #define ID_BUTTON_0 (GUI_ID_USER + 0x02)
    10. /*********************************************************************
    11. *
    12. * Static data
    13. *
    14. **********************************************************************
    15. */
    16. /*********************************************************************
    17. *
    18. * _aDialogCreate
    19. */
    20. static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {
    21. { WINDOW_CreateIndirect, "Window", ID_WINDOW_0, 0, 0, 320, 240, 0, 0x0, 0 },
    22. { EDIT_CreateIndirect, "Edit", ID_EDIT_0, 87, 101, 137, 47, 0, 0x64, 0 },
    23. { BUTTON_CreateIndirect, "Set Value", ID_BUTTON_0, 50, 45, 80, 20, 0, 0x0, 0 },
    24. };
    25. /*********************************************************************
    26. *
    27. * Static code
    28. *
    29. **********************************************************************
    30. */
    31. /*********************************************************************
    32. *
    33. * _cbDialog
    34. */
    35. static void _cbDialog(WM_MESSAGE * pMsg) {
    36. WM_HWIN hItem;
    37. int NCode;
    38. int Id;
    39. float Value;
    40. switch (pMsg->MsgId) {
    41. case WM_INIT_DIALOG:
    42. //
    43. // Initialization of 'Edit'
    44. //
    45. hItem = WM_GetDialogItem(pMsg->hWin, ID_EDIT_0);
    46. WIDGET_SetEffect(hItem, &WIDGET_Effect_None );
    47. EDIT_SetText(hItem, "123");
    48. EDIT_SetTextAlign(hItem, GUI_TA_HCENTER | GUI_TA_VCENTER);
    49. EDIT_SetFont(hItem, GUI_FONT_20_1);
    50. EDIT_SetFloatMode(hItem, 30, 10, 50, 2, GUI_EDIT_SUPPRESS_LEADING_ZEROES);
    51. break;
    52. case WM_NOTIFY_PARENT:
    53. Id = WM_GetId(pMsg->hWinSrc);
    54. NCode = pMsg->Data.v;
    55. switch(Id) {
    56. case ID_BUTTON_0: // Notifications sent by 'Set Value'
    57. switch(NCode) {
    58. case WM_NOTIFICATION_RELEASED:
    59. hItem = WM_GetDialogItem(pMsg->hWin, ID_EDIT_0);
    60. Value = -999999999.567f;
    61. EDIT_SetFloatValue(hItem, Value);
    62. break;
    63. }
    64. break;
    65. }
    66. break;
    67. default:
    68. WM_DefaultProc(pMsg);
    69. break;
    70. }
    71. }
    72. /*********************************************************************
    73. *
    74. * MainTask
    75. */
    76. void MainTask(void) {
    77. WM_HWIN hWin;
    78. GUI_Init();
    79. GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);
    80. while (1) {
    81. GUI_Delay(100);
    82. }
    83. }
