How to create a Progress bar in Ring shape ?
  • How to create a Progress bar in Ring shape ?
    How to create a progress bar in ring shape ? Similar to one shown below ? In this case only outer ring with Dot and the couter should increament! I understood that with skin we can implement. But for better clarification if you can share some code snippet of this implementation it would be better.
    Unfortunately I do not have any code exsamples. But I would suggest either to create a new widget from scratch or to overwrite the callback of the progressbar widget and handle the drawing and the touch input.
    For creating a custom widget, please take a look into this application note:
    segger.com/downloads/emwin/AN03002_Custom_Widget_Type.pdf
    Hi Sven,
    I'm using 2D- Graphic Library to draw that ring based on timer. How can i move or draw that small "Filled Circular Pointer" everytime ? As the ring progresses, that pointer should also progress. So ultimately it will move in circular shape. Please guide.
