Wstrict-prototypes
  • Wstrict-prototypes
    Hi!
    Since switching to SES v3.12 I have started to encounter compiling error:
    1. '-Wstrict-prototypes' is valid for C/ObjC but not for C++
    I have a project where I mix up C++ and C, so any extern "C" allocation declarations ending up with this compiler error.
    When following multiple threads about this, I have hit the suggestion that one should somehow disable this flag at the global compiler settings - source .
    I get the same error for -Wno-strict-prototypes.
    I am using gnu11 and gnu++1y compiler standards.
    Is there any workaround for this?
    Cheers!
    To prevent this error you will need to remove the compiler warning option -Wstrict-prototypes instead of negating it with -Wnostrict-prototypes
    The option is most commonly set on sloution level or project level in your project in the option Additional C/C++ Compiler Options.
    Once you removed the option you can re-add it to the Additional C Compiler Only Options
    Johannes
