I am using 2.40e (and also tried 2.41a beta) with FreeRTOS under Linux (Centos 7) in load data from a .bin file mode.
1)
My Event log shows:
xQueueGenericSend xQueue=0x00000000 ...
The description file has %I which from the documentation says should be replaced with a 'named resource' if available. I believe the bug is that since it is not available, it should be printing the resourceId in hex, but not 0.
I verified the data in the file contains a non-zero value.
2)
If I highlight the xQueueGenericSend in the event list and press Shift-N to goto the next event of the same type, the program hangs and CPU usages goes to 100%. Occasionally it might work, but normally it hangs.
EDIT: Just tried 2.4.2 and same hang.
Also, it would be nice if the File -> Load (at least during the same session) remembered the last directory of the previously loaded file. Every time I load a new file, the file chooser resets back to the directory systemview was run from and I need to renavigate.
1)
My Event log shows:
2)
The post was edited 1 time, last by krbvroc1 ().
