[SOLVED] JFlash command line options not working
  • [SOLVED] JFlash command line options not working
    I am using JFlash 6.10l on two different Windows 10 machines.
    On one machine there is no problem, everything works fine.
    But on the second machine, I cannot use the CLI.
    Running for example the following command, starts J-Flash, but doesnt exit as expected:
    "C:\Program Files\SEGGER\JLink\V610l\JFlash.exe" -exit
    Calling
    "C:\Program Files\SEGGER\JLink\V610l\JFlash.exe" -?
    or
    "C:\Program Files\SEGGER\JLink\V610l\JFlash.exe" -min
    works also fine
    Also more complex commands like
    "C:\Program Files\SEGGER\JLink\V610l\JFlash.exe" -openprjC:\mk22.jflash -openC:\fw.hex -auto -exit
    are not working
    Starting JFlash normal and use it by mouse works also fine on this machine.
    Any suggestions how to find a solution for this problem?
    Best,
    Stefan
  • Hello Stefan,
    we just released a new JFlash 6.14 software version.
    You can download it here: segger.com/downloads/jlink
    Could you give it a try and report to us if the issue got resolved?
    If it does not resolve the issue, could you please post the complete content of the J-Flash Log?
  • It is not possible for me to install a newer Version of JFlash, on my first machine it works fine with the same version V6.10l.
    This is the J-Flash log:
    1. Application log started
    2. - J-Flash V6.10l (J-Flash compiled Nov 7 2016 16:51:16)
    3. - JLinkARM.dll V6.10l (DLL compiled Nov 7 2016 16:51:01)
    4. Reading flash device list [C:\Program Files\SEGGER\JLink\V610l\ETC\JFlash\Flash.csv] ...
    5. - List of flash devices read successfully (451 Devices)
    6. Reading MCU device list ...
    7. - List of MCU devices read successfully (6199 Devices)
    after executing the following command:
    The same command works fine on my first machine. The .jflash and .hex file are also existent and like I said it works, wenn running it manually.
  • Hello Stefan,
    this error was not reproducible in our lab, but this issue has been reported by some customers.
    So far we were able to pinpoint the problem to a remote desktop service running in the background, e.g. TeamViewver.
    As a workaround please try to deinstall, or disable TeamViewer or the remote desktop you are using on the machine where the issue occurs.
    We are currently working on a solution to this and it will probably be release in the next couple of weeks.
  • Hi Stefan & Forum,
    Issues with J-Flash caused by remote desktop services like TeamViewer are fixed in versions 6.15a and higher of the J-Link software & documentation pack (beta)
