I am using a JLINK base debugger (S/N 50104346) to debug an STM32F756 microcontroller. I am using Eclipse neon.1 with the latest GNU ARM C/C++ J-Link debugging plugin (v 4.1.1). My Eclipse project also incorporates Freertos and the debug configuration includes the option "-rtos GDBServer/RTOSPlugin_FreeRTOS" so that the Freertos threads can be viewed in the stack trace viewer in Eclipse. I am using GDB Server "V6.12 Command Line Version".
With the FreeRTOS debug configuration option enabled, if there is more than one FreeRtos task and they have differing priorities and if I set a break point in one of the tasks, I receive the following error message in the GDB server console output and the GDB server shuts down:
…Breakpoint reached @ address 0x08008F1
WARNING: Mis-aligned memory read: Address: 0x0000000F,
NumBytes: 4, Alignment: 4 (Word-aligned)
WARNING: Failed to read memory @ address 0xECBC865D
ERROR: Error reading thread name in FreeRTOS task control
block.
Reading all registers
WARNING: Mis-aligned memory read: Address: 0xECBC8629,
ERROR: Error reading stack frame from FreeRTOS task.
Has this error been seen by other users on this forum and is there a solution to it?
Kind regards
Jack
block.
Kind regards
Jack
