[ABANDONED] STM32F767 - trace ETM
  • [ABANDONED] STM32F767 - trace ETM
    Hi
    I'm trying to activate the ETM trace (TRACED[0-3] + TRACECK) on my STM32F767BI
    I download "Ozone J-Trace PRO Tutorial Project" at segger.com/ozone-trace-tutorial.html to see how to use it on STM32
    But i didn't find (or didn't understand) how you activate the trace. On this exemple I can only see basic function whitout relation to trace.
    Do you have some documentation or exemple ?
    I use a J TRACE with ozone (or eclipse).
    Code is compiled with GNU ARM GCC
    what is displayed in the Instruction Trace window of Ozone ?
    (View->Instruction Trace)
  • When I load my program I get some information
    [img]http://zupimages.net/up/17/04/3r5h.png[/img]
    and the trace seems to work until I try to configure the clock
    [img]http://zupimages.net/up/17/04/f0we.png[/img]
    but when i run my soft and stop it a few functions after, i have no data
    [img]http://zupimages.net/up/17/04/4flj.png[/img]
    my µC is running at 192MHz
    The post was edited 1 time, last by Brice_38_FR ().
    so it seems to be functional in general.
    Does trace stop working exactly when clock is switched? Or could it be that Pins are reconfigured shortly before or after?
    Are you sure? Maximum core clock of the device is 216 MHz, and Trace clock is usually 1/2 of core clock.
    J-Trace only supports up to 100MHz Trace clock (J-Trace Pro supports 150MHz).
    Therefore you either need to use a core clock of <200MHz or (if possible by chip design) change the Trace clock to core clock ratio.
  • About the cpu speed: I'm sure about 192MHz, I configure it at this speed in CubeMx to be able to use the trace :) but i will check to be sure
    I remove all code after the clock initialisation to be sure about gpio reconfiguration and I still loss trace after the clock initialisation.
    I look deeper in the SystemClock_Config function and i find that the trace stop when I enter in the function HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_6) at l:46
    1. void SystemClock_Config(void)
    2. {
    3. RCC_OscInitTypeDef RCC_OscInitStruct;
    4. RCC_ClkInitTypeDef RCC_ClkInitStruct;
    5. RCC_PeriphCLKInitTypeDef PeriphClkInitStruct;
    6. /**Configure the main internal regulator output voltage
    7. */
    8. __HAL_RCC_PWR_CLK_ENABLE();
    9. __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
    10. /**Initializes the CPU, AHB and APB busses clocks
    11. */
    12. RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSI|RCC_OSCILLATORTYPE_HSE;
    13. RCC_OscInitStruct.HSEState = RCC_HSE_ON;
    14. RCC_OscInitStruct.LSIState = RCC_LSI_ON;
    15. RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
    16. RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
    17. RCC_OscInitStruct.PLL.PLLM = 12;
    18. RCC_OscInitStruct.PLL.PLLN = 192;
    19. RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
    20. RCC_OscInitStruct.PLL.PLLQ = 8;
    21. if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    22. {
    23. Error_Handler();
    24. }
    25. /**Activate the Over-Drive mode
    26. */
    27. if (HAL_PWREx_EnableOverDrive() != HAL_OK)
    28. {
    29. Error_Handler();
    30. }
    31. /**Initializes the CPU, AHB and APB busses clocks
    32. */
    33. RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
    34. |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
    35. RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
    36. RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
    37. RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
    38. RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
    39. if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_6) != HAL_OK)
    40. {
    41. Error_Handler();
    42. }
    43. PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_USART1|RCC_PERIPHCLK_USART3
    44. |RCC_PERIPHCLK_UART4|RCC_PERIPHCLK_UART5
    45. |RCC_PERIPHCLK_I2C1|RCC_PERIPHCLK_I2C2
    46. |RCC_PERIPHCLK_I2C3|RCC_PERIPHCLK_I2C4;
    47. PeriphClkInitStruct.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK2;
    48. PeriphClkInitStruct.Usart3ClockSelection = RCC_USART3CLKSOURCE_PCLK1;
    49. PeriphClkInitStruct.Uart4ClockSelection = RCC_UART4CLKSOURCE_PCLK1;
    50. PeriphClkInitStruct.Uart5ClockSelection = RCC_UART5CLKSOURCE_PCLK1;
    51. PeriphClkInitStruct.I2c1ClockSelection = RCC_I2C1CLKSOURCE_PCLK1;
    52. PeriphClkInitStruct.I2c2ClockSelection = RCC_I2C2CLKSOURCE_PCLK1;
    53. PeriphClkInitStruct.I2c3ClockSelection = RCC_I2C3CLKSOURCE_PCLK1;
    54. PeriphClkInitStruct.I2c4ClockSelection = RCC_I2C4CLKSOURCE_PCLK1;
    55. if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK)
    56. {
    57. Error_Handler();
    58. }
    59. /**Configure the Systick interrupt time
    60. */
    61. HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
    62. /**Configure the Systick
    63. */
    64. HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
    65. /* SysTick_IRQn interrupt configuration */
    66. HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
    67. }
    I am looking forward for your feedback.
    Another option would be to select a slower clock (e.g. 96 MHz) and test if this works.
    Switching the core / trace clock should not cause issues with the trace function of J-Link / Ozone.
  • So I check the speed with the function SEGGER_MeasureCPUPerformance() and I measure it before and after the clock configuration
    1. 0> SEGGER J-Link V6.12f - Real time terminal output
    2. 0> Process: Ozone.exe
    3. 0>
    4. 0> Loops/sec: 1150
    5. 0> Your target is running at 16 MHz.
    6. 0> This value is calculated in comparison to a reference Cortex-M4 running in iRAM with zero wait states and full compiler optimizations built on GCC V5.4.3 used in Segger Embedded Studio
    7. 0>
    8. 0>
    9. 0> Loops/sec: 13968
    10. 0> Your target is running at 194 MHz.
    11. 0> This value is calculated in comparison to a reference Cortex-M4 running in iRAM with zero wait states and full compiler optimizations built on GCC V5.4.3 used in Segger Embedded Studio
    12. 0>
    I don't have any code optimisation (-O0) and the debug optmisation is ondefault ( -g)
    I continue looking in the function "HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_6) " and I found that the trace stop working just after I configure the system clock source with __HAL_RCC_SYSCLK_CONFIG(RCC_ClkInitStruct->SYSCLKSource);
    edit: just saw your answer, will try cpu at 96MHz
    when using the 96MHz configuration..
    a) What does SEGGER_MeasureCPUPerformance() report?
    b) Could you please make a screenshot of the Rawtrace tab in the J-Link Control panel (can be opened by clicking the green J-Link icon in the system tray) while the application is been debugged and traced in Ozone, and the CPU is not stopped?
    thanks for the screenshot.
    So it works as expected - 96 MHz core clock, 48 MHz trace clock.
    Would it be possible for you to provide us with your project so that we can give it a try here?
  • Hi
    Yes I could send you the cubeMx project and/or the eclipse project. How do we proceed ?
    I did more tests and found that the trace is working with a 120MHz CPU
    The main difference between 120MHz and 192MHz is flash latency and overdrive
    [img]http://zupimages.net/up/17/04/pvsa.png[/img]
    I am currently pretty booked.
    Can you please provide all files/projects necessary to replicate and test the issue?
    Do you want to send it via mail or do you have some webspace yourself...?
