The error occurs when I try to pause the debugger, I get a 'Mis-aligned
memory read: Address: 0xA5A5A5B5, NumBytes: 4, Alignment: 4
(word-aligned)' The error message is coming from the JLink Log
I tested the Jlink+ using a standard JTAG interface and I did not get
the problem.
The only differences between the 2 systems are that the JTAG system is a
Cortex-M3, the error system is a Cortex-M0, debug interface is SWD, and
is running FreeRTOS. I also tested using the original CrossLink
debugger (Olimex design), level shifter board, interfaced using 2 signal wire SWD. I can start and stop
(pause) the debugger at will with no errors. It is something Jlink
related.
I'm using Rowley CrossStudio 3.5. Any idea about this?
the problem.
related.
