Hello Segger Team
The debugging SAVE function of ARM Keil uVision (5) can only store Intel HEX format. The Segger SystemView can only read binary or SVDat format.
(At least I did not find another solution)
It would be nice if SystemView could also handle Intel Hex file format or other formats than SVDat /binary.
Here how I did Segger SystemView integration into ARM Keil uVision (5).
Kind Regards
Roman
- Write a function using the uVision debugger scripting:
- FUNC void SaveSeggerSystemViewData(void) {
- printf("Saving Segger SystemView data in SeggerSystemViewData.hex!\n") ;
- exec("SAVE \"SeggerSystemViewData.hex\" (uint32_t)_SEGGER_RTT.aUp[0].pBuffer , ((uint32_t)_SEGGER_RTT.aUp[1].pBuffer + _SEGGER_RTT.aUp[1].SizeOfBuffer)");
- DEFINE BUTTON "Save Segger SystemView Data", "SaveSeggerSystemViewData()"
- Download the srecord tool from srecord.sourceforge.net/
- Intergrate srecord to convert the Intel Hex to a binary file:
[quote] Command: ../tools/srecord/srec_cat.exe
Arguments: SeggerSystemViewData.hex -intel -offset - -minimum-addr SeggerSystemViewData.hex -intel -o SeggerSystemViewData.bin -binary[/quote] A more generic way for converting any hex file which is part of the project:
Arguments: %F -intel -offset - -minimum-addr %F -intel -o @F.bin -binary [/quote]
Kind Regards
Roman
The post was edited 1 time, last by Roman ().
