[SOLVED] Ozone for Mac OSX crash
  • [SOLVED] Ozone for Mac OSX crash
    I noticed that recent Ozone releases for Mac OSX no longer able to load elf image. When I invoke "Download & Reset Program", it always crashes. :(
    I found v2.22a works find, but v2.22b and later releases crash without any messages. My Mac OSX version is 10.12.2, J-Link version is 6.12d.
    I am currently working with Ozone 2.22k under macOS 10.12.2, so this seems not to be a generic issue.
    Would it be possible for you to provide a .elf file for reproduction purposes'?
    My target is STM32 Nucleo-L476RG board which is J-Link flashed. Please find attached zipped elf file.
    I tested with Ozone v2.22k, but it crashed with this .elf.
    I also experienced same problem with STM32F767 target, but I can't provide the .ELF for this target.
    Tosh
    • UVCDisp.elf.zip
      (556.4 kB, downloaded 440 times, last: )
  • Hi Tosh,
    We were unsuccessful in reproducing the issue.
    We will contact you regarding this issue via the e-mail address you registered with.
    We will send you an unofficial version of Ozone that provides extended logging in this case.
  • I'm experiencing the same issue with Ozone v2.22m and Segger J-Link Edu on macOS Sierra 10.12.3 (16D32).
    Installed J-Link is 612g.
    Ozone crashes and quits when I click on any of the three Debug > Start Debugging options.
    Everything works fine with JLinkGDBServer and arm-none-eabi-gdb against an ATSAM3X8E.
    -device ATSAM3X8E
    -if swd
    -speed 4000
    Please find the .elf file attached.
    Ozone with the exact same project works fine on Windows 10.
    Thank you for your help.
    The post was edited 3 times, last by Avenue33 ().
    Unfortunately no luck to reproduce the crash.
    Could you create a log file from starting the debug session? (Call Project.SetJLinkLogFile("/Users/<UserName>/Desktop/JLink.log"); in your project)
    Johannes
  • Thank you for your answer. Please find the log file below.
    1. TF4D4000 000:000 SEGGER J-Link V6.12f Log File (0000ms, 0000ms total)
    2. TF4D4000 000:000 DLL Compiled: Jan 13 2017 16:40:56 (0000ms, 0000ms total)
    3. TF4D4000 000:000 Logging started @ 2017-01-31 12:18 (0000ms, 0000ms total)
    4. TB8B073C0 012:467 JLINK_DEVICE_GetIndex(sDeviceName = ATSAM3X8E) returns 244 (0090ms, 0090ms total)
    5. TB8B073C0 012:557 JLINK_DEVICE_GetInfo(DeviceIndex = 244) returns 0 (0000ms, 0090ms total)
    6. TB8B073C0 012:560 JLINK_DEVICE_GetIndex(sDeviceName = ATSAM3X8E) returns 244 (0000ms, 0090ms total)
    7. TB8B073C0 012:560 JLINK_DEVICE_GetInfo(DeviceIndex = 244) returns 0 (0000ms, 0090ms total)
    8. TB8B073C0 012:560 JLINK_DEVICE_GetInfo(DeviceIndex = 244) returns 0 (0000ms, 0090ms total)
    9. TB8B073C0 012:587 JLINK_DEVICE_GetInfo(DeviceIndex = 244) returns 0 (0000ms, 0090ms total)
    10. JLINK_GetpfGetInstInfo() returns 0
    11. TF4D4000 016:336 JLINK_EnableLog(...) (0000ms, 0090ms total)
    12. TF4D4000 016:336 JLINK_SetErrorOutHandler(...) (0000ms, 0090ms total)
    13. TF4D4000 016:336 JLINK_SetWarnOutHandler(...) (0000ms, 0090ms total)
    14. TF4D4000 016:336 JLINK_Open()
    15. Firmware: J-Link V9 compiled Dec 16 2016 15:34:10
    16. Hardware: V9.40
    17. S/N: 269401196
    18. OEM: SEGGER-EDU
    19. Feature(s): FlashBP, GDBWEBSRV Webserver running on local port 19080 (0013ms, 0103ms total)
    20. TF4D4000 016:336 returns O.K. (0013ms, 0103ms total)
    21. TF4D4000 016:349 JLINK_GetAvailableLicense()
    I'm using a J-Link Edu. Does Ozone require another model?
    The post was edited 1 time, last by Avenue33 ().
    We found an issue regarding additional J-Link licenses, which could cause the crash on macOS and Linux.
    Since J-Link PLUS already includes the license for Ozone, this combination does not crash.
    The fix will be part of the upcoming release of the J-Link software.
    Johannes
  • J-Link V6.12h includes just one important fix, but not the fix for the crash.
    A release which includes the fix for the crash (Ozone V2.22o and J-Link V6.12i) is planned for tomorrow.
    Johannes
  • Ozone V2.22o, which includes the new J-Link V2.12i, is available now.
    Johannes
    good to hear that you are up and running!
    /closed
