While debugging the M4 side on VF6xx_M4, if the M4 watchdog reset happens and system restarts, I cannot connect to it with JLink unless I power cycle the board.
This is both with JLinkGDBServer and JLinkExe.
JLinkExe tells me
****** Error: Vybrid Cortex-M4 (connect): Could not power up debug port.
TotalIRLen = 4, IRPrint = 0x01
Cannot connect to target.
GDB server tells me
SEGGER J-Link GDB Server V6.10c Command Line Version
JLinkARM.dll V6.10c (DLL compiled Sep 28 2016 18:30:23)
GDBInit file: none
Terminal I/O port: 2333
Generate logfile: off
Verify download: on
Init regs on start: on
Silent mode: off
Single run mode: on
J-Link Host interface: USB
J-Link script: none
J-Link settings file: none
Target device: VF6xx_M4
Target interface: JTAG
Target interface speed: 1000kHz
Target endian: little
Connecting to J-Link...
J-Link is connected.
Firmware: J-Link V10 compiled Sep 1 2016 18:29:58
Hardware: V10.00
S/N: xxxxxxxxxxxxxx
Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
Checking target voltage...
Target voltage: 3.33 V
Listening on TCP/IP port 2331
Connecting to target...ERROR: Vybrid Cortex-M4 (connect): Could not power up debug port.
ERROR: Could not connect to target.
Target connection failed. GDBServer will be closed...Restoring target state and closing J-Link connection...
Shutting down...
The system reset pin does not help, need power cycle. Why does this happen?
JLinkExe tells me
GDB server tells me
GDBInit file: none
Verify download: on
Silent mode: off
Single run mode: on
J-Link script: none
Hardware: V10.00
S/N: xxxxxxxxxxxxxx
Shutting down...
The post was edited 1 time, last by v01d ().
