Problem with GDB fetching CPSR value.
  • Problem with GDB fetching CPSR value.
    Recently I'm working on a AT91SAM9263 based project. I encountered a problem that the GDB debugger cannot step conditional jump instrution such as "beq 0x********". I notice that GDB is always thinking the register CPSR's value is 0xd3 when debugging program. Therefore, GDB misplaces the breakpoint needed for stepping and continues to run. See the following:
    GNU gdb (Sourcery G++ Lite 2009q1-203) 6.8.50.20081022-cvs
    Copyright (C) 2008 Free Software Foundation, Inc.
    License GPLv3+: GNU GPL version 3 or later <
    http://gnu.org/licenses/gpl.html>
    This is free software: you are free to change and redistribute it.
    There is NO WARRANTY, to the extent permitted by law. Type "show copying"
    and "show warranty" for details.
    This GDB was configured as "--host=i686-pc-linux-gnu --target=arm-none-linux-gnueabi".
    For bug reporting instructions, please see:
    https://support.codesourcery.com/GNUToolchain/>.
    (gdb) tar remote 192.168.5.9:2331
    Remote debugging using 192.168.5.9:2331
    0x00000000 in ?? ()
    (gdb) info reg
    r0 0x0 0
    r1 0x0 0
    r2 0x0 0
    r3 0x0 0
    r4 0x0 0
    r5 0x0 0
    r6 0x0 0
    r7 0x0 0
    r8 0x0 0
    r9 0x0 0
    r10 0x0 0
    r11 0x0 0
    r12 0x0 0
    sp 0x0 0x0
    lr 0x0 0
    pc 0x0 0
    fps 0x0 0
    cpsr 0xd3 211
    (gdb) mon regs
    PC = 23F15568, CPSR = 600000D3 (SVC mode, ARM FIQ dis. IRQ dis.)
    R0 = 00000000, R1 = 23F5F014, R2 = 00000000, R3 = 40001A1A
    R4 = 23E7EFC0, R5 = 00000000, R6 = 00000000, R7 = 00000000
    USR: R8 =23E7EFDC, R9 =00000000, R10=00000000, R11 =23E7ED90, R12 =23F51D74
    Actually, r0 to r15 can be changed when executing program. Whatever you do, even change CPSR's value directly, command "info reg" shows CPSR never changed.
    I have tried gdb 6.5 and gdb 6.8, J-Link 3.80a, 3.94 and 4.08i, the problem was all the same.
  • Hello cosine,
    This is fixed in the latest beta version of the J-Link GDB Server (V4.09b).
    Note: When changing a register's value, the "Flush regs" command has to be
    executed prior to the "info reg" command to invoke an update of the GDB's register cache.
    The latest beta version is available for download on our website:
    segger.com/download_jlink_beta.html
