J-Link, 5V Supply
  • J-Link, 5V Supply
    I'm unsure, I already sent one J-Link back as the 5V Supply seems dead, it does not supply 5V.
    I try to power an STM32F4 Discovery with it and double-double-checked the wiring already.
    I expected that there would be 5V available when I plug in the J-Link (measured between pin 4 and pin 19).
    I don't think the wiring is incorrect as when I externally power the Discovery board I can read a valid VTref on pin 1:
    SEGGER J-Link Commander V6.10c (Compiled Sep 28 2016 18:30:32)
    DLL version V6.10c, compiled Sep 28 2016 18:30:23
    Firmware: J-Link V9 compiled Sep 1 2016 18:29:50
    Hardware version: V9.40
    S/N: 269402916
    License(s): FlashBP, GDB
    OEM: SEGGER-EDU
    VTref = 2.958V
    On the other hand, I can't connect to the device, I still need to clarify this.
    I use J-Link on Linux, not sure if this may be related to the issue.
    Can anybody explain if my understanding is incorrect?
    Thanks for any hints,
    Torsten
    Yes, Kenny is right. In the default configuration J-Link does not supply power on pin 19.
    You can either switch it on permanently with J-Link commander and the command "power on perm" or until the next disconnect with "power on".
    Johannes
