Multiple Buffer
    Multibuffering is not available for this kind of driver.
    But you can use a chached version of your driver. Simply call GUIDRV_FlexColor_SetFunc() with e.g. GUIDRV_FLEXCOLOR_M16C1B16 as pfMode.
    Like:
    1. GUIDRV_FlexColor_SetFunc(pDevice, &PortAPI, GUIDRV_FLEXCOLOR_F66708, GUIDRV_FLEXCOLOR_M16C1B16);
    GUIDRV_FLEXCOLOR_M16C0B16 - ...C0.. is without cache and
    GUIDRV_FLEXCOLOR_M16C1B16 - ...C1.. is with cahce
    Any drawing will be done into the cache before sending it to the LCD.
    The Window Manager does this automatically. If you don't use the Window Manager you have to call
    1. LCD_ControlCache(LCD_CC_LOCK)
    before the drawing operation and
    1. LCD_ControlCache(LCD_CC_UNLOCK)
    after the drawing to flush the content of the cache to the LCD.
  • Thanks for the answer. I'll try.
    I'm going to use most of the display memory for drawing, since I have a lot of free memory in ssd1963. Will it work? Or you need to put external memory?.
    p.s. Sorry for my English
    If you are using a chached version of the driver cache will be on MCU side and not on the LCD side. The size of the cahche depends on the LCD size and the used color depths.
