tmp* files on OS X
  • tmp* files on OS X
    I've defined a single directory for my compiler output (*.d, *.o, *.elf, *.map etc). Over time I see a large number of files whose names begin with 'tmp'. Is this a bug? Can it be disabled?
    Silverback: ls tmp*
    tmpT2z7aY tmpgRuLoX tmptffH8U tmpyFE8nZ
    They seem to contain assembler output:
    .syntax unified
    .cpu cortex-m7
    .eabi_attribute 28, 1
    .fpu fpv5-d16
    .eabi_attribute 20, 1
    .eabi_attribute 21, 1
    .eabi_attribute 23, 3
    .eabi_attribute 24, 1
    .eabi_attribute 25, 1
    .eabi_attribute 26, 1
    .eabi_attribute 30, 1
    .eabi_attribute 34, 1
    .eabi_attribute 18, 4
    .thumb
    .syntax unified
    .file "ethernetif.c"
    .text
    .Ltext0:
    .section .text.low_level_input,"ax",%progbits
    .align 2
    .thumb
    .thumb_func
    .type low_level_input, %function
    low_level_input:
    .LFB144:
    .file 1 "/Volumes/Project/micromodulator/LWIP/Port/ethernetif.c"
    .loc 1 279 0
    @ args = 0, pretend = 0, frame = 0
    @ frame_needed = 0, uses_anonymous_args = 0
    .LVL0:
    push {r4, r5, r6, r7, r8, r9, r10, lr}
    .LCFI0:
    .LVL1:
    These are left-over output files from the compiler which should have been removed.
    The upcoming version will improve the handling, create non-random names and make sure they are removed.
    Johannes
