Solution to record start of the system
  • Solution to record start of the system
    Like other guys I had a problem to record start of the system. I know that SEGGER_SYSVIEW_Start() can be used to force recording even without active connection but It wasn't solution for me due to huge buffer needed to not get overflow issue.
    Therefore I prepared solution that is sufficient for and maybe will be useful also for other.
    I implemented blocking function:
    1. SEGGER_SYSVIEW_WaitForConnection()
    This function is called at start of the system just after SEGGER_SYSVIEW_Conf(). It is waiting endless till the System View application will be connected. Thanks that I don't lose any data at start and I don't need to worry about time when SysView will be connected.
    Function body:
    2. *
    3. * SEGGER_SYSVIEW_WaitForConnection()
    4. *
    5. * Function description
    6. * Wait endless when SystemView APP will be connected
    7. *
    8. * Additional information
    9. */
    10. void SEGGER_SYSVIEW_WaitForConnection (void)
    11. {
    12. do
    13. {
    14. _HandleIncomingPacket ();
    15. }
    16. while (0 == _SYSVIEW_Globals.EnableState);
    17. }
    I added it to SEGGER_SYSVIEW.c. If you think it is useful then feel free to add it to you system.
    Lukasz Antczak
  • Hi Lukasz,
    Thanks for sharing your function.
    It is a good solution to make sure you record the start of a system without adding a system specific delay or loop.
    Note: This function cannot be used in release code, as the system will endlessly wait for the SystemView connection.
    We might add it to the official version as well.
    Johannes
