SEGGER SystemView with RELAX Kit without OS using Infineon DAVE IDE
  • SEGGER SystemView with RELAX Kit without OS using Infineon DAVE IDE
    Hello
    Did anybody succeed to use SEGGER SystemView with RELAX Kit without OS using Infineon DAVE IDE?
    I configured it according to SEGGER manual, but when I start to record, my application stops in file startup_XMC4500.s:
    1. /* ================== START OF VECTOR ROUTINES ============================= */
    2. .align 1
    3. .thumb
    4. /* Reset Handler */
    5. .thumb_func
    6. .globl Reset_Handler
    7. .type Reset_Handler, %function
    8. Reset_Handler:
    9. ldr sp,=__initial_sp
    10. #ifndef __SKIP_SYSTEM_INIT
    11. ldr r0, =SystemInit
    12. blx r0
    13. #endif
    I used the supplied configuration in file SEGGER_SYSVIEW_Config_NoOS.c. Maybe something should be changed?
    To be able to connect to the XMC4500 J-Link has to do a reset of the device.
    Does SystemView work when you let it run after it hit the breakpoint in the reset handler?
    To work around this when a debugger (i.e. DAVE) is already attached to the target,
    you can in SystemView configure the device as Cortex-M4 and add the RTT Control Block search address manually.
    Then J-Link should be able to do the second connection to the device without a reset.
    Johannes
    You can check the address of _SEGGER_RTT with your debugger/IDE.
    Johannes
