[SOLVED] How can I turn off messages from J-Link
  • [SOLVED] How can I turn off messages from J-Link
    In my test bench I use two programmers J-Link Plus.
    When first or second can't program the micro I get error like below:
    [img]http://www.fotosik.pl/zdjecie/cffa120b9c96f870[/img]
    and always must I click "No" and "No".
    How can I turn off this message and set default answer "NO" ?
    Best Regards
    Michal
  • Hi Michal,
    The picture shows 2 (or more) programs running in parallel, which are using the same J-Link.
    The question only comes up if the first program choose another interface then the 2nd programm. (E.g first configured JTAG, 2nd one configured SWD).
    This usually indicates an unintentional misconfiguration, therefore the J-Link software asks if it is intentional. Since you choose"no" it seems like it was not your intention.
    I do this like below
    I run first J-Link
    JLink.exe - SelectEmubySN firstSerialNumber -speed 4000 -CommanderScript myscript.jlink
    and I'm waiting for Exit code.
    Next I run second J-Link
    JLink.exe - SelectEmubySN secondSerialNumber -speed 4000 -CommanderScript myscript.jlink
    Both use the same script:
    1. device TM4C1231E6PM
    2. eoe 1
    3. power on
    4. r
    5. sleep 100
    6. erase
    7. loadfile C:\myhex.hex
    8. g
    9. power off
    10. exit
    Where I made a mistake?
    Best Regards
    Michal
  • Hi Michal,
    You do not specify a Target interface. This can be done e.g via the commandline:
    1. JLink.exe - SelectEmubySN firstSerialNumber -speed 4000 -if JTAG -CommanderScript myscript.jlink
    BTW: You are using an old version of the J-Link software, with the current version (5.12j / 6.00c) it would not be possible to not define a target interface.
