Hi.
I have quite a number of frustrating experiences with the SAM-ICE here with the AT91SAM9263-ek.
1) 4.06b does not recognize the board when I want to use J-Mem. The error message is "SAM-ICE can only be used with ATMEL devices". Ha! I have one. Older versions have the same problem.
2) 4.07b recognizes the board in J-Mem, but it shows all blank (--------). It correctly reads past 0xE0000000, but that's not good enough. I don't know how I can read the memory below that address?
3) j-link itself works. I can connect and dump the registers. If I call 'mem 0x0, 0x32', it says "Could not read memory". Again, it can read it beyond 0xe0000000.
Is there any way to get that thing to work, or did I simply buy a blue piece of plastic?
Thanks a lot,
Kasi
SEGGER J-Link Commander V4.07b ('?' for help)
Compiled Jun 10 2009 19:56:38
DLL version V4.07b, compiled Jun 10 2009 19:56:22
Firmware: J-Link ARM V8 compiled May 27 2009 17:31:22
Hardware: V8.00
S/N : 28000905
OEM : SAM-ICE
Feature(s) : RDI
VTarget = 3.267V
Info: CP15.0.0: 0x41069265: ARM, Architecure 5TEJ
Info: CP15.0.1: 0x1D152152: ICache: 16kB (4*128*32), DCache: 16kB (4*128*32)
Info: Cache type: Separate, Write-back, Format C (WT supported)
#0 Id: 0x0792603F, IRLen: 4, IRPrint: 0x0 ARM926EJ-S Core
Found ARM with core Id 0x0792603F (ARM9)
ETM V1.3: 4 pairs addr.comp, 2 data comp, 8 MM decs, 2 counters, sequencer
JTAG speed: 5 kHz
J-Link>halt
PC: (R15) = FFFF0028, CPSR = 600000D7 (ABORT mode, ARM FIQ dis. IRQ dis.)
R0 = 00000000, R1 = 600000D7, R2 = 00000000, R3 = FE07F458
R4 = E3FE9960, R5 = 00000000, R6 = E3FE9960, R7 = 00000000
USR: R8 =00000000, R9 =00000000, R10=00000000, R11 =E3FFDFC8, R12 =FC4046AC
R13=E3C95420, R14=FE063E7C
FIQ: R8 =A531607C, R9 =AED6B312, R10=04C008C0, R11 =6600A54C, R12 =3E2B41F9
R13=FE07D458, R14=CE2F1BFC, SPSR=00000010
SVC: R13=E3FFDFBC, R14=FE0565F4, SPSR=6000001F
ABT: R13=FE07D438, R14=FFFF010C, SPSR=600000DF
IRQ: R13=FE07D448, R14=FC4046BC, SPSR=60000013
UND: R13=FE07D428, R14=00000008, SPSR=00000010
J-Link>mem 0x0,0x2
Could not read memory.
Thanks a lot,
Kasi
Hardware: V8.00
S/N : 28000905
OEM : SAM-ICE
Feature(s) : RDI
VTarget = 3.267V
JTAG speed: 5 kHz
J-Link>halt
J-Link>mem 0x0,0x2
