[SOLVED] ST Nucleo F411 SWO
  • [SOLVED] ST Nucleo F411 SWO
    I upgraded the STLink on my ST Nucleo F411 (STM32F411RE) board to JLink but I can't get SWO to work. Eclipse doesn't give me any error but no output either, the "Semihosting and SWV" console just says "SEGGER J-Link GDB Server V5.12g - Terminal output channel" but no output appears, although I'm sending to ITM stimulus port 0 continously. I checked the SWO header on the board and it is connected to PB3 via jumper SB15.
    Next thing I did was to connect directly using JLink Commander to interrogate the available SWOSpeed and the JLink Commander tells me
    1. *** J-Link V5.12g Warning ***
    2. The connected emulator does not support serial wire output (SWO).
    Here's the full interaction with JLink Commander:
    1. ➜ ~ JLinkExe
    2. SEGGER J-Link Commander V5.12g (Compiled May 27 2016 16:55:14)
    3. DLL version V5.12g, compiled May 27 2016 16:55:08
    4. Connecting to J-Link via USB...O.K.
    5. Firmware: J-Link STLink V21 compiled Apr 15 2016 10:47:22
    6. Hardware version: V1.00
    7. S/N: 775171134
    8. VTref = 3.300V
    9. Type "connect" to establish a target connection, '?' for help
    10. J-Link>connect
    11. Please specify device / core. <Default>: STM32F411RE
    12. Type '?' for selection dialog
    13. Device>STM32F411RE
    14. Please specify target interface:
    15. J) JTAG (Default)
    16. S) SWD
    17. TIF>S
    18. Specify target interface speed [kHz]. <Default>: 4000 kHz
    19. Speed>4000
    20. Device "STM32F411RE" selected.
    21. Found SWD-DP with ID 0x2BA01477
    22. Found SWD-DP with ID 0x2BA01477
    23. Found Cortex-M4 r0p1, Little endian.
    24. FPUnit: 6 code (BP) slots and 2 literal slots
    25. CoreSight components:
    26. ROMTbl 0 @ E00FF000
    27. ROMTbl 0 [0]: FFF0F000, CID: B105E00D, PID: 000BB00C SCS
    28. ROMTbl 0 [1]: FFF02000, CID: B105E00D, PID: 003BB002 DWT
    29. ROMTbl 0 [2]: FFF03000, CID: B105E00D, PID: 002BB003 FPB
    30. ROMTbl 0 [3]: FFF01000, CID: B105E00D, PID: 003BB001 ITM
    31. ROMTbl 0 [4]: FFF41000, CID: B105900D, PID: 000BB9A1 TPIU
    32. ROMTbl 0 [5]: FFF42000, CID: B105900D, PID: 000BB925 ETM
    33. Cortex-M4 identified.
    34. J-Link>SWOSpeed
    35. *** J-Link V5.12g Warning ***
    36. The connected emulator does not support serial wire output (SWO).
    37. *** J-Link V5.12g Warning ***
    38. Supported speeds:
    39. J-Link>q
    I'm running this on Mac OSX 10.10.5. My question is whether SWO is supported at all by JLink on ST Nucleo boards, or whether I'm doing something wrong or missing a crucial step.
    If it's not available, what alternatives do I have to send debug information back to my host computer using JLink? I want to avoid Semihosting if possible.
    Thanks in advance
    Simon
    The post was edited 1 time, last by simon42 ().
    The initial firmware did not support SWO. A new firmware is now available:
    segger.com/jlink-st-link.html
    We recommend SEGGER RTT:
    segger.com/jlink-rtt.html#RTT_How_RTT_works
    [img]https://www.segger.com/cms/admin/uploads/imageBox/RTT_SpeedComparison.png[/img]
    RTT sources ship free of charge with the J-Link software package, which is available here .
  • I'll reflash the new firmware and try again and also give RTT a try.
    Just to make sure that there are not misunderstandings:
    RTT has *nothing* to do with SWO!
    RTT also works without having the SWO pin connected. It also works on M0 targets which do not support SWO at all.
