[Segger Ozone] embosPlugin.dll
  • [Segger Ozone] embosPlugin.dll
    I have started looking at the Ozone debugger, and I am using Ozone with an existing project built with IAR Workbench 5.20. First of all, I was pleasantly surprised that Ozone understood the IAR generated symbols (then again - I don't know if IAR's symbol format is based on GDB's or what).
    But when I tried to use the embosPlugin.dll, the "Threads" window doesn't show any of the tasks. This feature does work fine in IAR 5.20 with the IAR embosPlugin.dll I have installed there. I am wondering if the problem I see in Ozone is due to the age of embOS that I am using - version 3.60d. Should the Ozone embosPlugin.dll work with this embOS version?
    IAR generated files are, like most files, in the ELF/DWARF format which Ozone can understand.
    Unfortunately the embOS plugin does not work with your version of embOS,
    you would have to update to a current version of embOS.
    Johannes
