Newbie:Unable to use emWin
  • Newbie:Unable to use emWin
    Hello
    I am using emWin through Dave IDE from infineon.
    I have multiple problems.
    1. I am unable to initialize SSD1963 based TFT screen of resolution 320*240
    I can do that by functions written by me.
    But function calls like
    GUI_SetBkColor(GUI_BLUE);
    Don't do anything. Probably no function seems to have been called.
    My project compiles okay without any error, so project does find GUI.h and other files.
    2. When I launch GuiBuilder , and drag anything to work area, I get an error
    "No valid parent dialog exists"
    Can someone point out where my mistake lies?
    Tired now after searching for entire last week
  • Moved from "SEGGER SystemView related" to "emWin related".
    calling the function GUI_SetBkColor() alone doesn't do anything. Afterwards you have to call a GUI_Clear() to fill the screen with the color set by GUI_SetBkColor().
    This should work:
    1. #include "GUI.h"
    3. *
    4. * MainTask
    5. */
    6. void MainTask(void) {
    7. GUI_Init();
    8. GUI_SetBkColor(GUI_BLUE);
    9. GUI_Clear();
    10. while (1) {
    11. GUI_Delay(100);
    12. }
    13. }
    Prior of adding any widgets you have to set a background window. The first step should be selecting either a frame window or a normal window.
  • Hello Sven
    Thanks for replying. I was not notified on my email about your reply...strange!!
    Anyways.
    I use SSD1963 with 8-bit MCU parallel interface.
    I wrote my own init routine and a standard SSD1963 driver from elsewhere.
    Now with this i can draw any color and any Bitmap on my screen (320x240, 5.7")
    Although when i integrate emwin in my project ,this does not happen.
    When i change my init code then some observation is observed as below..
    Sometimes only black color fills screen, sometimes entire screen is not covered.
    Sometimes the TFT doesnt initialise.
    I think some definitions in LCDconf.c and my init code do not agree with each other..
    I am attaching my init code and my conf file
    Can you correct it and post it here?
    Attached main.c and LCDconf.c files here
    Image of what i get on the LCD is attached too
    • Sources.zip
      (6.83 kB, downloaded 384 times, last: )
    The post was edited 1 time, last by abicash ().
