SystemViewer (OSX again) doesn't decode events when you start it by double-clicking, the usual way you start things, from the Applications directory or the launchpad. You get events which look like this ..
#115 01 01 00
The OS is being correctly identified as O=FreeRTOS and the description file is in the right place
/Applications/SystemViewer.app/Contents/MacOS/description/SYSVIEW_FreeRTOS.txt
which is right alongside the application
/Applications/SystemViewer.app/Contents/MacOS/SystemViewer
If you actually go to that directory and run SystemViewer from a command prompt
./SystemViewer
it works correctly. So I suspect that running it the usual way with a double-click sets the current working directory to the package or your home directory or no directory at all and I suspect too that systemviewer uses whatever the current working directory is to hunt for the description subdirectory, so it doesn't find it.
You can work around it by command-line launching, but it would be nice to have that fixed.
This is v2.35a.
EDIT: actually I can answer the question about what directory CWD is set to on a standard double-click launch, it's '/', yes the root directory. That definitely won't contain any description. So searching relative to current working directory isn't going to work very well.
#115 01 01 00
./SystemViewer
This is v2.35a.
The post was edited 1 time, last by rols ().
