Our company has a VMware image of Linux (kubuntu 8.04) that other groups do some embedded ARM development with, using other JTAG devices. I'm trying to use our J-Link from within that VM to see if it will work for our current project.
I have downloaded the Linux software package version 5.12f, TGZ archive and extracted to /usr/local/JLink_Linux_V512f_i386.
I have installed the udev rules as described in the readme.
I have an MSP-EXP432 Launchpad board connected to the VM just for something to play with until we get real hardware. The JTAG slide switch is set for external.
I have the J-Link connected to the VM and the target via a 20-way to 10 way adapter.
If I try to run JLinkExe and control the target it looks like it communicates with the J-Link OK but not the target:
If I disconnect the J-Link from the VM and try the same parameters from J-Link Commander natively under Windows then it can connect and I can control the target OK. However, I'm not sure where to start trying to figure out why it won't work under the VM. Any suggestions?
Thanks.
- dmcminn@dmcminnvm:/usr/local/JLink_Linux_V512f_i386$ ./JLinkExe
- SEGGER J-Link Commander V5.12f (Compiled May 17 2016 16:01:00)
- DLL version V5.12f, compiled May 17 2016 16:00:55
- Connecting to J-Link via USB...ShowEmO.K.
- Firmware: J-Link Ultra V4 compiled Apr 22 2016 11:48:35
- Hardware version: V4.00
- S/N: xxxxxxxxx
- License(s): RDI, FlashBP, FlashDL, JFlash, GDB
- VTref = 3.280V
- Type "connect" to establish a target connection, '?' for help
- J-Link>ShowEmuList
- J-Link[0]: Connection: USB, Serial number: 504302945, ProductName: J-Link ULTRA+
- J-Link>connect
- Please specify device / core. <Default>: MSP432P401R
- Type '?' for selection dialog
- Device>MSP432P401R
- Please specify target interface:
- J) JTAG (Default)
- S) SWD
- TIF>J
- Device position in JTAG chain (IRPre,DRPre) <Default>: -1,-1 => Auto-detect
- JTAGConf>-1,-1
- Specify target interface speed [kHz]. <Default>: 4000 kHz
- Speed>1000 kHz
- Device "MSP432P401R" selected.
- Selected interface (0) is not supported by connected debug probe.
- J-Link>
Thanks.
