[Segger Ozone] Function to get "file size" ?
    You are correct. There is no function to get the file size.
    For which purpose would you need this in Ozone?
    Johannes
    Thanks for your reply.
    I need to know the file size for my dowload/flash procedure (I can't use the one provided by Segger).
    But if I can call a batch file, I could use an external script for that. Is it possible?
    No, it is not possible to call/execute external scripts with Ozone.
    In general Ozone is a debugger.
    For any automated tests or production purposes we recommend using the J-Link SDK to develop a dedicated solution/application.
    (segger.com/jlink-sdk.html)
    Johannes
