[Segger Ozone] How to load symbols from an axf without its code?
  • [Segger Ozone] How to load symbols from an axf without its code?
    In Ozone script, I need to load symbols from an *.axf but not the code part.
    But when I do "File.Open("file.axf");", it indeed loads the symbols but also seems to execute the code inside, which I want to avoid.
    Is there a way to do it?
    Thanks.
    If you want to only load symbols, but not download the code, you can switch the mode to attach to running program.
    This can be done by adding Edit.SysVar (VAR_CONNECT_MODE, CM_ATTACH); before File.Open() in OnProjectLoad().
    Johannes
