gcc: SEGGER_RTT_Conf.h:59:75: error: expected expression before ')' token : "=r" (SavedState)
  • gcc: SEGGER_RTT_Conf.h:59:75: error: expected expression before ')' token : "=r" (SavedState)
    I'm trying to build my firmware with the System View target sources included. This is for an ARM Cortex M0 and I'm using this version of gcc:
    gcc-arm-none-eabi-4_9-2015q1
    The build fails on compiling SEGGER_SYSVIEW.c as follows:
    1. In file included from SEGGER_SYSVIEW_ConfDefaults.h:62:0,from SEGGER_SYSVIEW_Int.h:62,from SEGGER_SYSVIEW.c:133:SEGGER_SYSVIEW.c: In function '_APrintHost':SEGGER_RTT_Conf.h:59:75: error: expected expression before ')' token:"=r" (SavedState) \
    Here's the inline assembler source that's causing the error:
    1. #define SEGGER_RTT_LOCK(SavedState) {\asm volatile ("mrs %0, primask \n\t" \"mov r1, $1 \n\t" \"msr primask, r1 \n\t" \: "=r" (SavedState) \: \: "r1"\ );\ }
    How do I fix this?
    Could you update your SystemView and RTT sources to the latest version which is included in SystemView?
    Johannes
  • Thanks for the feedback, good to read it is working now.
    Johannes
