j-link (It doesn't work properly)
  • j-link (It doesn't work properly)
    Hello! It is impossible to force to work for me JTAG adapter j-link for the speed more than 32kHz. Prompt what to do.
    Thankful in advance.
    IAR Embedded Workbench for ARM 5.30.1 Evaluation
    Wed Jan 28 15:00:22 2009: DLL version: V4.2 , compiled Jan 13 2009 20:12:45
    Wed Jan 28 15:00:22 2009: Firmware: J-Link compiled Feb 20 2006 18:20:20 -- Update --
    Wed Jan 28 15:00:22 2009: JTAG speed is initially set to: 32 kHz
    Wed Jan 28 15:00:22 2009: Initial reset was performed
    Wed Jan 28 15:00:22 2009: TotalIRLen = 4, IRPrint = 0x01
    Wed Jan 28 15:00:22 2009: J-Link found 1 JTAG device(s). ARM core Id: 3F0F0F0F ARM7
    Wed Jan 28 15:00:22 2009: Device at TAP0 selected
    Wed Jan 28 15:00:22 2009: JLINK command: ProjectFile = I:\!!!\!\settings\1234_Debug.jlink, return = 0
    Wed Jan 28 15:00:22 2009: JLINK command: device = AT91SAM7X256, return = 0
    Wed Jan 28 15:00:22 2009: Auto JTAG speed: 2666 kHz
    Wed Jan 28 15:00:26 2009: Fatal error: Memory access timed out @ FFFFF240 -> JTAG speed too high ?
    SEGGER J-Link Commander V4.02 ('?' for help)
    Compiled Jan 13 2009 20:12:59
    DLL version V4.02, compiled Jan 13 2009 20:12:45
    Hardware: V3.00
    S/N : 3185
    OEM : IAR
    VTarget = 3.371V
    Id of device #0: 0x3F0F0F0F
    Found ARM with core Id 0x3F0F0F0F (ARM7)
    JTAG speed: 5 kHz
  • Hello jedi,
    the AT91SAM7X starts with 32 kHz CPU clock after reset (slow clock, internal oscillator)
    and the hardware version V3 of J-Link ARM can not handle JTAG speeds for AT91SAM7X
    which are much higher than the CPU speed.
    The easiest way to use higher JTAG speeds is to use a macrofile which switches the clock source to the main oscillator.
