ADS7846 example
  • ADS7846 example
    Do you have any example of using the GUITDRV_ADS7846 touchscreen driver?
    The info in the manual is a bit lacking, an example of the GUITDRV_ADS7846_CONFIG pfSendCmd and pfGetResult callbacks would be very helpful.
    The attachment shows a sample how to use the driver.
    • TouchConf.zip
      (2.08 kB, downloaded 1,179 times, last: )
  • Thanks for the reply, still struggling to get your driver working however. See my code below.
    I have tested that I am getting valid data back from the touch controller, stepping through the assembly it appears to never call GUI_TOUCH_StoreStateEx.
    As another test I wrote a new driver and called GUI_TOUCH_StoreStateEx myself, this is actually working ok.
    Cheers
    1. static void platform_touch_send_cmd(U8 Data)
    2. {
    3. /* Sends a 8-bit command to the peripheral */
    4. HAL_StatusTypeDef status = HAL_SPI_Transmit(&handle_spi, &Data, 1, 100);
    5. if (status != HAL_OK) {
    6. DEBUG_BREAK();
    7. }
    8. }
    9. static U16 platform_touch_get_result(void)
    10. {
    11. /* Retrieves the result of the AD conversion. */
    12. uint8_t buffer[2] = {0};
    13. uint8_t dummy[2] = {0};
    14. HAL_StatusTypeDef status = HAL_SPI_TransmitReceive(&handle_spi, dummy, buffer, 2, 100);
    15. if (status != HAL_OK) {
    16. DEBUG_BREAK();
    17. }
    18. uint16_t result = be_to_h_u16(buffer);
    19. result >>= 3;
    20. return result;
    21. }
    22. static char platform_touch_get_busy(void)
    23. {
    24. /* Retrieves the status of the busy line. 0: Not busy; 1: Busy */
    25. //GPIO_PinState gpio_state = HAL_GPIO_ReadPin(GPIOC, GPIO_PIN_1);
    26. //return (gpio_state == GPIO_PIN_SET);
    27. return 0;
    28. }
    29. static void platform_touch_set_cs(char OnOff)
    30. {
    31. /* Set chip select line. OnOff == 1 means peripheral selected */
    32. HAL_GPIO_WritePin(GPIOA, GPIO_PIN_4, (OnOff == 1) ? GPIO_PIN_RESET : GPIO_PIN_SET);
    33. }
    34. static char platform_touch_get_penirq(void)
    35. {
    36. /* Retrieves the status of the PENIRQ line to detect a touch event.
    37. * return 1 if a touch event is recognized and 0 if not. */
    38. GPIO_PinState gpio_state = HAL_GPIO_ReadPin(GPIOC, GPIO_PIN_0);
    39. return (gpio_state == GPIO_PIN_RESET);
    40. }
    41. static GUITDRV_ADS7846_CONFIG touch_config = {
    42. .pfSendCmd = platform_touch_send_cmd,
    43. .pfGetResult = platform_touch_get_result,
    44. .pfGetBusy = platform_touch_get_busy,
    45. .pfSetCS = platform_touch_set_cs,
    46. .Orientation = GUI_MIRROR_Y,
    47. .xLog0 = 0,
    48. .xLog1 = (PANEL_WIDTH - 1),
    49. .xPhys0 = 0,
    50. .xPhys1 = 4095,
    51. .yLog0 = 0,
    52. .yLog1 = (PANEL_HEIGHT - 1),
    53. .yPhys1 = 0,
    54. .yPhys0 = 4095,
    55. .pfGetPENIRQ = platform_touch_get_penirq,
    56. };
