I have a board with a STM32F446 cpu and where VDD is 1.8V. The related datasheet says that when VDD is between 1.7V and 2.1V, the flash can only be programmed bytewise. I tried to download an image to flash inside gdb with the "load" command but it does not work, it seems that JLinkGDBServer is using a transfer size greater than a byte. Is there a way to configure GDBServer in order to get a bytewise transfer when I run the "load" command? If not is there another alternative to have bytewise flash downloading?
Best Regards,
Fabien
Best Regards,
Fabien
