Hi all,
I'm using STemWin5.26 in a project based on my
own board equipped with the STM32F429I MCU, Serial Flash with SPI interface,
SDRAM and LCD (RGB565).
All graphical objects are compressed using BitmapConverter (best palette +
transparency, saved as RLE8 DTA stream) and stored in the Serial Flash memory
as raw data.
I am able to display single images using GUI_DrawStreamedBitmapEx() and GetData function,
but in my application I want to utilize advantages of BUTTON widget. I'm trying
to set an image from the Serial Flash memory to the button directly using BUTTON_SetStreamedBitmapEx() -but with no success.
Is it even possible, or what is the best way in this case?
Thank you in advance.
Mira
as raw data.
Mira
