[SOLVED] J-Link Debugger: Save Terminal Text
  • [SOLVED] J-Link Debugger: Save Terminal Text
    Hi all,
    I'm evaluating J-Link Debugger to see if it is suitable for some automated tests. Is there a way to save the content of the terminal window to a file from a script? Something like Window.Save("Terminal", "result.log")?
    Are there some more example scripts in addition to the manual? Could be inspiring.
    Thomas
  • Hi Skoe,
    Currently, there is no save function for the terminal output, but will be added in the near future.
    No, but every function is described in the manual. In addition to that, every action which is performed by using the GUI is logged in the terminal with the corresponding script command.
  • Thank you, Niklas.
    I have some more issues and questions regarding the debugger. Hope this is the right place to ask.
    Following functions don't work here (1.78). The second one was shown in the Console window when I added it to the watch list manually.
    1. Watch.Set(gMainReturnValue);
    2. Watch.Set("gMainReturnValue");
    3. Break.SetOnSymbol(gMainReturnValue, AT_WRITE_ONLY, AW_WORD, 0x0, 0xFFFFFFFF);
    4. Break.SetOnSymbol("gMainReturnValue", AT_WRITE_ONLY, AW_WORD, 0x0, 0xFFFFFFFF);
    They cause error messages like this:
    1. Syntax error at line 10: Watch.Set...
    2. Unknown identifier at line 10: Break.SetOnSymbol...
    gMainReturnValue is actually listed in the Globals window.
    Another question, is it possible to
    - evaluate program variables in scripts
    - set the return value of the debugger, so it can be seen in the calling Makefile
    it could look like this (sorry for the weird invented function names :)
    1. if (Util.EvalU32(gMainReturnValue) != 0) {
    2. Util.Log("Test failed.");
    3. File.Exit(1);
    4. }
    5. else {
    6. Util.Log("Test passed.");
    7. File.Exit(0);
    8. }
    Is what I try too far from the intended use of J-Link Debugger? If you are planning to add features like this (in case they aren't there yet), what is an *approximate* realistic time frame? I like the clean, quick user interface of this debugger, that's why I would like to use it in our project.
    Thank you for your help!
    Thomas
    The post was edited 1 time, last by skoe ().
  • Hi Thomas,
    The issues regarding Watch.Set and Break.SetOnSymbol have been fixed in V1.79 of J-Link Debugger.
