How to load LPC2919 using J-Link
  • How to load LPC2919 using J-Link
    I am using J-Link to load code into LPC2919. Keil MCB2900 board
    In Segger website, I knew that J-Link support ARM9 and ARM Cotex.
    Now I try to use J-Link Flasher/J-Linker command line to load code into LPC2919.
    In Flasher, I configure Project for ARM 9, change the ID, Flash address, RAM address suitable for LPC2919. But, when I connect to LPC2919. Flasher can not connect and display these error:
    Connecting ...
    - J-Link firmware: V1.20 (J-Link ARM V6 compiled Dec 05 2008 20:04:57)
    - JTAG speed: 200 kHz (Fixed)
    - Initializing CPU core (Init sequence) ...
    - Initialized successfully
    - JTAG speed: 100 kHz (Fixed)
    - J-Link found 1 JTAG device. Core ID: 0x0596802B (ARM9)
    - Reading CFI info ...
    - Could not find CFI compliant flash device
    - Detecting flash memory ...
    - ERROR: Could not find any flash devices
    - ERROR: Bad JTAG communication: Write to IR: Expected 0x1, got 0xe (TAP Command : 15) @ Off 0x1979.
    - ERROR: Failed to connect
    Pls give a hand to solve the LPC2919 loading
    hoanf
    Vietnam
  • Hello hoanf,
    currently J-Flash does not support programming of the internal flash of the LPC2919.
    We are working on it.
    We will inform you, as soon as a new version of the J-Link software is available which includes support.
