TI CC2640/CC2650 and J-Link on command line.
  • TI CC2640/CC2650 and J-Link on command line.
    Target is CC2640/CC2650. I'm trying to load a very simple blink LED application compiled via gcc. I was able to build the blink_led example from the swra446 example without using Eclipse, really simply on the command line.
    But, was unsuccessful loading it into a stripped-down SensorTag using a Segger J-link. See output below.
    Anyone out there have any success with CC2640 and J-Link? The TI e2e employees are just telling me to use the XDS.
    J-Link> loadbin blink_led.bin 0x0, fails with the following:
    $ JLinkExe -if jtag -device CC2650F128
    SEGGER J-Link Commander V4.96l ('?' for help)
    Compiled Feb 25 2015 10:24:59
    Info: Device "CC2650F128" selected.
    DLL version V4.96l, compiled Feb 25 2015 10:24:52
    Firmware: J-Link V9 compiled Feb 20 2015 09:20:19
    Hardware: V9.30
    S/N: 269303671
    OEM: SEGGER-EDU
    Feature(s): FlashBP, GDB
    VTarget = 2.777V
    Info: TotalIRLen = 10, IRPrint = 0x0011
    Info: Found Cortex-M3 r2p1, Little endian.
    Info: FPUnit: 6 code (BP) slots and 2 literal slots
    Info: TPIU fitted.
    Found 2 JTAG devices, Total IRLen = 10:
    #0 Id: 0x4BA00477, IRLen: 04, IRPrint: 0x1, CoreSight JTAG-DP (ARM)
    #1 Id: 0x8B99A02F, IRLen: 06, IRPrint: 0x1, TI ICEPick
    Cortex-M3 identified.
    Target interface speed: 100 kHz
    J-Link>loadbin blink_led.bin 0x0
    Halting CPU for downloading file.
    Downloading file [blink_led.bin]...
    ****** Error: Failed to erase sectors 7 @ address 0x00003800 (erase error)
    Info: J-Link: Flash download: Total time needed: 0.921s (Prepare: 0.600s, Compare: 0.218s, Erase: 0.023s, Program: 0.000s, Verify: 0.000s, Restore: 0.078s)
    Unspecified error -1
    Thanks!
    Brian
  • Hi Brian,
    As I can see from the output you posted, you are using V4.96l of the J-Link software.
    Could you please give the current version a try?
    segger.com/jlink-software.html
    There have been bugfixes for the CC26xx series devices in later versions.
    - Alex
