buggy firmware upgrade by 3.96d version of GDB server?
  • buggy firmware upgrade by 3.96d version of GDB server?
    We use the Atmel AT91SAM-ICE JTAG emulator version of the J-Link ARM to load a program into the RAM of an Atmel AT91FR40162SB device (ARM 7 CPU and embedded flash), which we use in a hand device, as part of our flash programming process.
    I had been using my AT91SAM-ICE JTAG emulator successfully with version 3.74i of the Segger J-Link GDB Server for some time.
    I recently tried upgrading to version 3.96d of the Segger J-Link GDB Server. I now find that the AT91FR40162SB device is no longer recognized. I have returned to version 3.74i, but it is still no longer recognized.
    When I start the J-Link Commander program, I get this line:
    Firmware: J-Link compiled Jul 30 2008 11:24:37 ARM Rev.5
    This date is only four months ago, even though I have had my AT91SAM-ICE well over a year.
    Also, the same line for another AT91SAM-ICE device that still works is:
    Firmware: J-Link ARM V6 compiled Oct 10 2007 19:39:24
    So I conclude that version 3.96d of the Segger software has reflashed my SAM-ICE with buggy firmware.
    Is this a known problem? Perhaps it affects other J-Link ARM devices too? Is there some way to restore the original firmware?
    Is this the correct forum to ask this? Can anyone suggest a more appropriate place?
  • Hello cmacdonnell,
    there should be no problems when using SAM-ICE + J-Link GDB Server with your target device.
    Could you please post a more detailed description of your problem?
    Posting the complete output of J-Link commander (when using the SAM-ICE which does not work)
    would also be useful in order to investigate this.
    How to downdate the firmware:
    Described in UM08001 (J-Link / J-Trace User Guide), chapter "9.7.2 Invalidating the firmware".
    Download UM08001
  • Here is the full output from J-Link Commander for the SAM-ICE that fails:
    SEGGER J-Link Commander V3.74i ('?' for help)
    Compiled Sep 11 2007 14:43:12
    DLL version V3.74i, compiled Sep 11 2007 14:43:07
    Hardware: V5.40
    S/N : 20004833
    OEM : SAM-ICE
    Feature(s) : RDI
    VTarget = 0.000V
    ****** Error: Supply voltage too low (1 Volt is required, Measured: 0.0 Volt).
    Please check target power.
    JTAG speed: 30 kHz
    Here is the full output from J-Link Commander for the SAM-ICE that still works:
    Hardware: V6.00
    S/N : 26004027
    OEM : SAM-ICE
    Feature(s) : RDI
    VTarget = 0.000V
    Volt).
    JTAG speed: 30 kHz
    I see that the hardware version is different.
    Thanks for the link to the newer manual. I could not find information about downdating firmware in the manuals for V3.74i. I hesitate to use the procedure described there for the moment, due to these cautions that appear in the manual:
    Note: Downdating J-Link / J-Trace is not recommended, you do it at your own risk!
    Note: Note also the firmware embedded in older versions of JLinkARM.dll might not execute properly with newer hardware versions.
    It is possible, I suppose, that the firmware that used to be in my SAM-ICE was newer than the firmware in V3.74i, and so I could run afoul of the second caution. Could you advise me on this please? Is the firmware in V3.74i safe to use with my hardware version V5.40 SAM-ICE?
    J-Link commander output:
    sorry for the confusion, what I meant is that it would be useful to see if the communication with the target
    in general works with the SAM-ICE containing the newer J-Link firmware. So the output when a target is connected would be useful.
    GDB Server problem:
    What exactly happens when you are trying to use the SAM-ICE with the newer firmware version?
    Downdating the firmware:
    There should be no problem by downdating the fimrware to 3.74i.
    Bets regards,
    > target in general works with the SAM-ICE containing the newer J-Link firmware. So the output when
    From J-Link Commander V3.74i:
    Firmware: J-Link compiled Jun 28 2007 10:45:08 ARM Rev.5
    Hardware: V5.40
    S/N : 20004833
    OEM : SAM-ICE
    Feature(s) : RDI
    VTarget = 1.132V
    JTAG speed: 30 kHz
    ****** Error: Target VCC failure. Please check target voltage.
    Could not find supported CPU core on JTAG chain
    Trying to connect with 5 kHz !
    J-Link Commander V3.96d output:
    SEGGER J-Link Commander V3.96d ('?' for help)
    Compiled Nov 21 2008 19:00:17
    DLL version V3.96d, compiled Nov 21 2008 18:59:52
    Hardware: V5.40
    S/N : 20004833
    OEM : SAM-ICE
    Feature(s) : RDI
    VTarget = 1.138V
    Info: TotalIRLen = ?, IRPrint = 0x..00000000000000000000000000000000
    WARNING: No matching core found. Selecting default core (ARM7).
    JTAG speed: 5 kHz
    J-Link GDB Server V3.96d GUI window:
    GDB Waiting for connection Initial JTAG speed Auto
    J-Link Connected Current JTAG speed Auto
    Target Not connected 1.13V
    Log output
    SEGGER J-Link GDB Server V3.96d
    JLinkARM.dll V3.96d (DLL compiled Nov 21 2008 18:59:52)
    Listening on TCP/IP port 2331
    J-Link connected
    Hardware: V5.40
    S/N: 20004833
    OEM: SAM-ICE
    Feature(s): RDI
    > GDB Server problem:
    As the facsimile of the J-Link GDB Server GUI window above shows, "Target" remains "Not connected".
    As one would then expect, running GDB fails.
    I tried the firmware from V3.74i. But no joy. Although I did momentarily see "Target" in the GDB Server GUI window momentarily change to "ARM ...", or something like that. This was just for an instant. So I do not know what the rest of the text was. It did not stay long enough to try using GDB to load a program to RAM.
    J-Link Commander V3.74i output using V3.74i firmware:
    Hardware: V5.40
    S/N : 20004833
    OEM : SAM-ICE
    Feature(s) : RDI
    VTarget = 1.132V
    JTAG speed: 30 kHz
    I do not recall using J-Link Commander until I had the problem after upgrading to V3.96d. J-Link GDB Server always worked for me (I never bothered showing the "Log output" either). I only tried J-Link Commander to try to troubleshoot the problem. So I do not know if the "Target VCC failure" message has always been there. I will ask my colleague with the working SAM-ICE to see what he gets. But there have been know changes to the hardware I am using (unless I have damaged the JTAG port or connector strap or something, which I doubt).
  • It appears that I must have damaged the JTAG plug I am using at the same time I happened to upgrade my firmware. Where my colleague does the same test he gets a "VTarget" over 3 volts:
    Hardware: V6.00
    S/N : 26004027
    OEM : SAM-ICE
    Feature(s) : RDI
    VTarget = 3.125V
    JTAG speed: 30 kHz
    Id of device #0: 0x1F0F0F0F
    Found ARM with core Id 0x1F0F0F0F (ARM7)
    I only get a "VTarget" of 1.1 volts.
    Sorry for the fuss. Thanks for your help.
