I'm wondering, if somebody has programmed a MSP432 with a Segger J-LINK product successfully?
Using the Segger GDB-Server i can connect to the target and run the 'load exec.elf' command in
my arm-none-eabi-gdb. It tells me nothing about anything that got wrong. The transfer rate is displayed
so that i have assumed the programming was successfull. But after resetting the target, the old
firmware is starting up and it don't look like there has been anything programmed.
I have used commands for the device (mon flash device = MSP432P401R) and - even if deprecated -
the download to flash option (mon flash download = 1). Nothing changes the described behavior.
I'm using V5.0.0f if that is important to know.
Besides, it is a bit strange, that the official "Supported TI Devices"-Page states, that
the MSP432 has no Internal Flash. That's wrong, of course.
Writing to the support just results in a note, that i should use the forum, because i only have the EDU device.
Don't know if that is customer friendly, if something is provable wrong on their homepage...
