emFile and NOR Flash problem
  • emFile and NOR Flash problem
    I am trying to use emFile with SST39VF3201B microchip NOR flash.
    The code is:
    void FS_X_AddDevices(void) {
    FS_AssignMemory(&_aMemBlock[0], sizeof(_aMemBlock));
    // Add driver
    FS_AddDevice(&FS_NOR_Driver);
    // Set physical type, single CFI compliant NOR flash chips with 16 bit interface
    FS_NOR_SetPhyType(0, &FS_NOR_PHY_CFI_1x16);
    // Configure a single NOR flash interface (4 Mbytes)
    FS_NOR_Configure(0, NOR_FLASH_BASE, NOR_FLASH_BASE, 0x00400000);
    void MainTask(void)
    FS_NOR_DISK_INFO DiskInfo;
    NORFLASHInit();
    FS_Init();
    // Check if low-level format is required
    if (FS_IsLLFormatted("") == 0)
    printf("Volume is not low-level formatted. Low level formatting...\n");
    FS_FormatLow("");
    // Check if volume needs to be high level formatted.
    if (FS_IsHLFormatted("") == 0)
    printf("Volume is not high-level formatted. High level formatting...\n");
    FS_Format("", NULL);
    ShowDiskInfo(&DiskInfo);
    while (1)
    OS_Delay(100);
    void ShowDiskInfo(FS_NOR_DISK_INFO* pDiskInfo)
    char acBuffer[80];
    FS_X_Log("Disk Info: \n");
    FS_NOR_GetDiskInfo(0, pDiskInfo);
    sprintf(acBuffer," Physical sectors: %d\n"
    " Logical sectors : %d\n"
    " Used sectors: %d\n", pDiskInfo->NumPhysSectors, pDiskInfo->NumLogSectors, pDiskInfo->NumUsedSectors);
    FS_X_Log(acBuffer);
    But the result is:
    FS warning: NOR: Found multiple work sectors of identical size. Low level format invalid.
    FS error: FS_LocatePartition: Invalid BytesPerSector value: 0.
    FS error: FS_FAT_CheckBPB: Invalid BytesPerSector value: 0.
    Disk Info:
    Physical sectors: 1024
    Logical sectors : 6442
    Used sectors: 0
    What is the problem ?
    Can anyone help me ?
    Best regards.
    Leonardo F. Farah
  • Hi Leonardo,
    Are you using emFile v 4.00?
    In this case, you should read chapter "15.1 Differences from version 3.x to 4.x" in UM02001_emFile.pdf.
    ... or (what it boils down to) try adding
    1. FS_NOR_SPI_SetHWType(0, &FS_NOR_HW_ST_M25_Default);
    just after FS_NOR_SetPhyType(0, &FS_NOR_PHY_CFI_1x16);
    just a guess
    Stefan
  • Stefan,
    Thank you for your help.
    Since I am evaluating emFile I think that there is no v4.0 compilation for Keil and LPC1788.
    I used FS_NOR_PHY_CFI_1x16 physical layer because my NOR is parallel and no SPI.
    I solved the problem by re-writing the physical layer.
    Thank you again for your help.
    Best regards.
    Leonardo.
