J-FLASH ARM with LPC2468
  • J-FLASH ARM with LPC2468
    my board is LPC2468 and I'm trying to download a program to the external flash (SST39VF3201) but I can do it only on the slow mode. I was trying to use RAM addr = 40000000 64Kb but I got this error:
    Programming target (4194304 bytes, 1 range) ...
    - RAM tested O.K.
    - ERROR: Programming failed @ address 0x80000000 (program error)
    - ERROR: Failed to program target
    Thanks for any help!
    Hagen
  • Hello Hagen,
    Do I understand you correctly?:
    If you do not use the internal RAM of the
    LPC2468 programming works and if you enable "Use target RAM" in J-Flash, it will not.
    I do not see a reason why this should not work correctly.
    Could you please send the following information to support@segger.com?:
    - J-Link serial no.
    - Project file
    - Data file (hex / mot)
    - J-Flash Log window output
    In order to generate the logfile, please do the following:
    - Set the log level of J-Flash to "All messages"
    - Reproduce the problem
    - Copy contents of the log window to a file
  • Hello Hagen,
    we have analyzed this and we have come to the following result:
    There is a Problem with SST flashes because the RAMCode downloaded by J-Flash ARM checks Bit 5 (Data line 5) during erase
    and program (it should get high when an error during programming/erasing occurs). For the SST flash you use, the behaviour
    of this pin during programming/erasing is not specified. So in this case we get an "1" even if no error occured. We will fix this
    in the next beta version of the J-Link software which will be released next week.
  • Hello Hagen,
    we have built a new release version of the J-Link software (V4.00) in which this problem is fixed.
    The latest release version can be downloaded from our website: segger.com/download_jlink.html
