font converter missing fonnts
  • font converter missing fonnts
    When I open font dialogue in font converter there is no "Script" combobox, and many fonts are missing.
    With other programs that use the font dialogue, the font dialogue is full with all available fonts, and the script box is displayed.
    I tried the demo last version, I am using ST font converter version, it is the same.
    What is the problem? ( OS windows 8 )
    Johanan
    The post was edited 2 times, last by johanan ().
  • Hello Johanan,
    This might be likely caused by the Windows font settings. Please refer to the section "Font Converter" -> "Troubleshooting" in the emWin user manual for detailed information on how to make all fonts available in the Font Converter.
    Adrian
  • Unfortunately this did not help.
    Control Panel\All Control Panel Items\Fonts\Font settings
    Once the checkbox "Hide fonts based on language settings" is checked, all Windows
    fonts installed on the computer should be shown in the ’Font’ dialog.
    I also tried running the program in WIN 7 compatibility mode, with same result.
    Johanan
  • [img]E:\User_Johanan\Pictures\ScreenHunter\fcv.jpg[/img]Version is (ST)V5.26
    compiled 10:10:06 on Aug 14 2014
    (see attched jpg).
    I tried also on WIN 7 x64 (another PC) with same results, font setting OK (hide is checked).
    any way my current OS is windows 8.1 x64
    I also added font selection , as you can see the script select is missing.
    Johanan
    The post was edited 1 time, last by johanan ().
  • If this was the case, then you were correct. unfortunately it is not so.
    See attached screen with the actual fonts in my PC, compared to the list in the font converter. Since they are sorted , it easy to see.
    Johanan
  • Hello Johanan,
    I am not sure what this is about. You are telling me the script selection control is missing, but pointing me to missing fonts.
    I tested the Font Converter V5.26 on MS Windows 8.1. The missing fonts are caused by the same Windows setting which I mentioned above.
    Adrian
