I'm using emWinGUIBuilder V5.22 and would like to know if there is a newer version of this tool that might support that notion of a common graphics library? I have quite a large number of screens that need to be drawn up and it would be more efficient to just create a graphics library so that graphics that are frequently used don't need to be replicated (in terms of memory use).
GUIBuilder - common graphics library?
Of course dialogs which are created using the GUIBuilder can be reused in an application as often as required. In general it is recommended to delete a dialog once another dialog is created/shown.
Adrian -
I'm actually not referring to dialogs but graphics themselves that are repeated on multiple dialogs. What's a good way to manage those graphics so I can only have a single instance of each graphic and yet still make use of the emWinGUIBuilder? I guess I'm looking for some automation here which may not exist.
Yes, indeed. Unfortunately it is currently not possible to reuse exactly the same bitmap with the GUIBuilder without having it stored twice in the resulting c file. We will consider changing this in a future emWin version.
Adrian
Share
- Facebook 0
- Twitter 0
- Google Plus 0
- Reddit 0
